Super Elex IP#
  • Super Elex IP#
    Is the number on the hard disk or on the board?
    So it goes.
    Re: Super Elex IP#
    The IP address is listed on the printed label of the Super Elex. It is typically 192.168.XXX.XXX. You'd have to edit it in the IP Address Edit program under -Start, Programs, Steltronic, IP Address Edit. Make sure you leave a space between the XXX.XXX.XXX.XXX and the = sign as well as the odd lane of the pair.
    EXAMPLE:
    192.168.10.23 = 1
    192.168.10.17 = 3
      Re: Super Elex IP#
      I mean the hard disk of the superelex.
      Where in the super elex is the ip stored?
      Biggest problem with the super elex is the powerboard or a failing hard disk(about 5GB), I was wondering if I can replace them easily...
      So it goes.
        Re: Super Elex IP#
        We had a problem of this kind some time ago, I will send a PM to you at the beginning of week, for more information.
        82/30' S and me, it is a long story
          Re: Super Elex IP#
          Merci!
          So it goes.
            Re: Super Elex IP#
            Mormal my friend .
              Re: Super Elex IP#
              What kind of video signal is coming out of the De-9 connector ?
              VGA,PGA,EGA,RGB?????
              So it goes.
                Re: Super Elex IP#
                It's like a CGA. Red, Blue, Green, Ground and composite HV sync. I don't know if the sync is + or -. I'd have to look at my documentation. The primary difference is the horizontal frequency 15 kHz.
                  Re: Super Elex IP#
                  Like this ?
                  So it goes.
                    Hi
                    I have same issue. My hard drive in super elex is death. I would like to do disk image from another one, but I don't know where to change IP adress.
                    Can anybody help me?
                      Hello
                      Clone HDD from other lane and change the IP in C:\NOS\AUTOEXEC.NOS and C:\SAFETY\WATTCP.CFG
                        Thank You.
                        I will try that.
                          Thanks again.
                          I had a problem to make a clone off CF card from another super elex (card was broken too).
                          It need to have 2 partition - 1st is Dos, 2nd program.
                          Second one doesn't work, but I make it manual and copy files.
                          I've change IP and now everything is working.
                          I'm appreciate Your help Szakalit.
