Auto off spot with Steltronic and 82-90xl
  • Auto off spot with Steltronic and 82-90xl
    HI
    Does anybody know if it's possibly to have an Auto off-spot function with this setup ?
    Steltronic Wins 6.2.0
    Amf 82-90xl
    When i pull out the Steltronic interface on the chassis, i have the Auto off-spot function, but can't see any options in Wins where
    i can change it....
    82/90Xl and 82/90Xli
    What is the current value of Advanced Pinsetter parameter 1Fh?
      I have no idea of what you are asking for, will be more than happy to help if i can, but need some more info of what you are looking for...
        Guido or someone else in Steltronic Tech Support will have to tell you a password to get into 'advanced parameters' on the Dr. screen of that pair. This is where one changes some settings, including getting 2nd ballsignal through the scoring cable vs a wire to the mask bulb. Maybe he'll send you a PM with the instructions.
          Like Ted wrote, i´ll need a password to tell u that..
            Brian, have you contacted the Service department in Italy?
            They will give you all the support you need.
            Best Regards
            Guido
              Have contacted Steltronic in Italy, thu their website 7 days ago...but no answer..
              Found out that the value of the Advanced pinsetter parameter in 1Fh is set to 0.
              Any suggestions ??
                We need to know the current version of your firmware in the API?
                Please click the Doctor icon at the bottom of the WINS software, then click the gold box icon for the pair of lanes with the problem, then let us know that the version of "E-PROM" software is stated in the center of the screen.
                Thanks,
                Jim Osdale
                Steltronic Technical Support
                Jim Osdale
                Steltronic USA
                  Any suggestions ??
                  Change it to a value of 16
                  Best Regards
                  Guido
                    HI
                    Amf 82-90xl
                    i can change it....
                    For the Auto off-spot feature to work properly in the API, you need to verify that firmware version "FE" is installed.
                    Once you have verified that version FE is installed, you can change parameter 1FH to = 16, because if parameter 1FH is set to 0, this means the Auto off-spot is disabled.
                    After the parameter is changed to 16, (this will enable the auto off-spot feature), reboot the Super Elex, and then check to see if the problem has been solved. You may also need to reset the API, and you can use the reset button on the side of the API box, or removing power to the API is also the same result.
                    Jim Osdale
                    Jim Osdale
                    Steltronic USA
                      Hi Jim, thanks for your answer..tried to set the parameter 1Fh to 16, but didn't work.
                      How and where do i check that the firmware "FE" is installed ??
                      Brian
                        The E-Prom is F7
                          Ask them for a firmware update for the API. You'll store it on the server, then send it to the APIs.
                            Best Regards
                            Guido
                            Like Ted and Jim pointed out, i will need a firmware update for the API...
                            Any help here Guido ?
                              Brian,
                              you have to contact Steltronic service department with an email to [email protected] or calling +390302190830
                              Best Regards
                              Guido
