GSX Head Mechanic Needed, Sanford Fl
  • GSX Head Mechanic Needed, Sanford Fl
    GSX Head Mechanic
    Head Mechanic will be responsible for repair and maintenance of all bowling Brunswick GSX pinsetters and bowling maintenance equipment. The Head Mechanic will also be responsible for repair and maintenance of facilities show equipment and facility equipment including but not limited to kitchen equipment, basic A/C maintenance, and some facilities repair.
    Job description
    Enhance guest experience by maintaining bowling equipment. Preform preventative maintenance on all bowling equipment, and facilities equipment. Replace bad light bulbs. Train and schedule pin chasers, and work with operations management.
    Specific Responsibilities
    1. Perform preventative maintenance on bowling equipment per maintenance schedule.
    2. Repair bowling equipment when needed.
    3. Maintain Approach, oil bowling lanes.
    4. Maintain lane cleaning machine.
    5. Along with bowling manager control and inventory bowling supplies.
    6. Maintain facility show equipment
    7. Preform facility repair when needed.
    Skill/Experience: Brunswick GSX mechanic, consolidated electronics experience, Kustodian ION lane. ( bumpers ) Pinball Wizard I & II, Our center will provide training on Kustodian ION lane machine and consolidated electronics if needed.
    Would prefer some electronics repair.
    Job Activities
    1. Basic computer skills and spread sheet familiarity.
    2. Use of ladders.
    3. Use of hand tools.
    4. Use of test equipment example: Digital Volt Meter, calipers, depth gauge.
    5. Use of cleaning and lubrication chemicals.
    Working Hours: Must be available for all shifts including weekends and holidays.
    In interested please contact Peter Borrero, email resume to [email protected]
Help-broken Part
Greeting all.
Thanks for looking.
Bolton454
Pin Damage
Making TDM's adjustable.
1:1 shaft wear
