Hiring Assistant Head Mechanic for 82-70's
  • Hiring Assistant Head Mechanic for 82-70's
    We are hiring an assistant head mechanic at All Star Lanes - Baton Rouge, a 64 lane bowling center with 82-70's. We are looking for an Assistant Head Mechanic. Competitive rates, benefits and will help with relocation. If interested, please reply or send resume to kbogan@allstarlanesbr.com
Worn LBS Rudder Cams
82/70 cups springing back
The issue:
After pins are set down on first ball the cups snap back into the horizontal position hard, hitting the tops of the pins and knocking them down (first video)....
The AMF dude
Turret 1-7-10 problem
Gear box stand
The time is drawing near to pull my first gear box... pulling it because the bottom 2 1:1 bolts are strips. Going to try to repair with heli-coil...
anyway back on...
