A22 Oil Pressure Too High Message
  • A22 Oil Pressure Too High Message
    Seriously -- for a friend who asked for help:
    They had started oiling lanes and after a few lanes, the machine stopped and gave the Oil Pressure Too High message. In the maintenance chart is says Pressure set too high as one of the items, but does not point to how to set it, adjust it, lower it or anything. Suggestions?
    I haven't touched an A22 in over a year and didn't run them that much to begin with, so I don't really have any good ideas here.
    Thanks.
    The pressure on the oil side isn't operator adjustable like it is on the cleaning side but rather is controlled by the computer, pressure control valve and the pressure sensor. Check your electrical connections at the control valve and sensor. You can go into diagnostics in the GUI to check to make sure these two components are functioning. Replace if defective.
      Got it, thanks.
        After things start running back to normal, I would get a sharpie and mark the spot where you adjusted it to. After time, due to vibration, p.m's, and your conditioner line wearing out... the control valve will go out of adjustment. It's safe to mark your spot for future reference... Ran with a A22 for 4 1/2 years and I do not miss those reoccurring issues.
          I'll pass this on to them, thanks.
