Authority A 22
  • Authority A 22
    Greetings from Europe
    I'm having trouble with the Authority 22 cleaning machine. After starting the machine and placing it on track 1, the machine moves by about 4 - 5 meters (differently, sometimes even 6 meters) and then displays the following message on the display: * The End of Lane Sensor is not working properly. * I tested the sensor as follows:
    * Adjusting the 2nd generation End of Lane Sensor
    There is no adjustment necessary for this type of End of Lane Sensor. Check and make sure the sensor is operational by using the GUI and navigating to the Maintenance> Diagnostics> Sensors screen. Check the sensor by placing your hand under the sensor to check and see if the End of Lane sensor button on the GUI screen is changing color state. If so the End of Lane Sensor is working fine. * ( Brunswick Tech Support Knowledgebase (novosolutions.net) )
    I tested the machine in an upright position.
    Above all, I wonder if it is possible that the sensor has failed? I would like to be 100% sure before ordering a new sensor.
    Thank you very much for the information.
    greetings ....
    Darko
    p.s. Google translate
    Nobody knows? The sensor is not cheap, so I would like to make sure if the sensor failure is responsible for this error .... greetings
    Ball Returns Shorted Out?
    Trip rocker arm
    Lower ball cushion board
    Backend motor plug
    82/70 combi motors
