Units of oil ?????
  • Units of oil ?????
    How many units of oil are you guys putting out in the middle for a THS. does 80 to 90 units sound about right for the 1st zone. Thanks steve
    Sounds like a bit high, we do 75 in the middle until 12 feet, and after that the volume goes down to 10 units at 37 feet.
    With the machine you got some patterns, The A22 house 1 is a good and easy pattern.
      Do you use a zero for your last zone so your machine just buffs out last zone ? Thanks steve
        You are right about that! The last zone is until 41 feet all at 0.
