A-22 V2.0 putting oil where it shouldn't be..
  • A-22 V2.0 putting oil where it shouldn't be..
    I am useing a 40' house shot, and my A-22 is putting oil on boards R5 thru R16 all the way to the pin deck. I have checked everything that I know to do and can't figure this out. Any suggestions?
    Mechanical Opperations Supervisor
    Mac Daddy's LLC
    Okay, first off, since it's only putting it on a certain area of the backend, your buffer brush is raising as it should. When you say it's putting oil on 5-16, is it droplets of oil from the injectors or is it a smear of oil? 'Cause if it is a smear of oil, check the foam pad that's on the bottom of the machine just above the buffer brush when the machine is standing up. The adhesive may have let go on part of it and the foam pad is dragging on the lane. Had this happen once here, though not such a wide area. Mine was a 3 board strip of oil.
      I'll check the foam, and it seems like a smear. It almost looks like the injectors are still fireing past 40'.
      Mac Daddy's LLC
        If the injectors were causing it, you would see tiny droplets of oil. That foam pad comes loose easily when you use a towel to squeegee the oil from it rather than blot the oil from it. That was our issue here when we first got the A-22 a few years ago. And contact cement doesn't work well to re-glue it to the machine bottom. Just buy a new pad and then be sure to blot the oil from it. Since we figured that out, that foam hasn't come loose for us for probably over 2 years now. I keep a spare foam pad in stock.
          I figured my problem out. The front right transition roller bracket was bent enough to let the foam squeegee drag the lane. Thanks for the help..
          Mac Daddy's LLC
            Glad you found it. That bracket must've been bent pretty bad. How the heck did that happen? Anybody fess up to maybe dropping the machine when setting it down or something else like that?
              Couldn't get anyone to fess up to dropping the machine. That looks like what happened though.
              Mac Daddy's LLC
