New chapter to the dripping A22
  • New chapter to the dripping A22
    Ok now this is getting a bit frustrating. For the last two or three weeks i guess no dripping at all. lanes still palying the same on the house shot and everything has been fine. Well it was time to flip the squeege this past friday and low and behold the dripping came back. now again i can only get 40 lanes done with out drips every where. nothing else has been changed just a flip of the squeegee. I have tried everything. i have two big absorbant pads you put in the machine and they both fill up at 40 lanes. I have raised the buffer up as per several brunswick guys have told me and it gets a touch better but not good enough. its dripping from the removable pads and yes they are the heavy duty ones. And no its not coming from the rear cover i already checked that. you can see where the drips apear and its not coming from any hoses or fittings. as that is all solid and has been updated with pressure fittings. im at a loss.
    Just chaming in hear
    When you flip squeegee did you chang the squeegee mountings strip also or just flip the squeegees
    The reson i ask is some machines the mountings are made at a slitly defrent to compsaste [ frount and back ]
      Naw wepauls i didnt cause on this machine you can flip them because the plate will go either way.
        Can I correctly assume that the 2-3 weeks of no dripping was the result of replacing the buffer brush fuse? Did you check the fuse again? I asked in your previous thread if you loosened the buffer belt tension from where you had adjusted it to?
        http://www.popevil.com
        http://www.facebook.com/popevil
        http://www.dandirito.smugmug.com
          the mchine kinda took care of its dripping problem so im assuming it was the buffer. we raised it to where it just barley touches and now no worries.
