Conditioner Annoying Problem
  • Conditioner Annoying Problem
    what the fark !
    so im oiling my lanes and went to check it out on the lanes, on the first 10, 7 pin side boards there is conditioner all the way down to the pin deck,
    i contacted brunswick and they sent me 3 new boards, machine controller PCB, injector driver PCB and the motor controll PCB, all three didnt work..
    what else is there ??
    The very first thing I would check for would be clogged spray tips. If the tip clogs, the machine will simply squeegee the existing oil all the way down the lane. The way I personally check it is to push the machine out on the lane a couple feet, go to: Maintenance- Diagnostics-Cleaning, and run the cleaner pump for about 6 seconds. Shut the pump off. Pull the machine back and look at the puddle. It should extend all the way across the lane with no breaks. If you have a clogged tip it will be really obvious.
    41 years and still learning....
    lanedoctor@hotmail.com
      Looks like they covered all the bases on PC Boards. Those injectors are very reliable however I would be suspicious of an issue with the injector itself being stuck open.
      Mike Wilson
      Bowl-Tech Inc..
        When the machine gets to the end of the oil part, everything should be raised. With that done, if the injectors are still firing you will see the "dots" of conditioner down the lane. If instead you are seeing a smear all the way from the pin deck, I would look at the cleaning side. Specifically cloth and foam parts to see if something is dragging.
          Originally posted by KL_Chris86 View Post
          what the fark !
          Were you able to isolate the problem? What did it turn out to be?
          http://www.popevil.com
          http://www.facebook.com/popevil
          http://www.dandirito.smugmug.com
