I have a pair of lanes that the bumpers are not working at all. They both work with the hand held tester. Not sure where to start looking. Qubica Conquer with Brunswick bumpers. Thanks for any help.
No bumpers with Quibica
Check white cable wiring from Brunswick bumper controller going to QubicaAMF bumper interface unit (small black box), and blue cable wiring going to scorer interface unit ("PS INTERFACE"). Hopefully a wire is just cut.or loose. DSCF0604.JPG
Not certain what BIU and SIU hardware QubicaAMF has for a-2 pinsetters. The photo above was installed for GSX pinsetters to communicate with QubicaAMF touch screen scorer pads, (where bumper control is given to the bowlers). Bumper controller dip switch is set to "lane 1-2" on every lane pair; daisy-chain cables are disconnected.
