On the piston for these is the screw in connector for the air line. I have a few that have developed leaks. From the looks of the manuals you can not order this part seperately to replace. What is it called? Any one have some sort of specs for them so I can try and hunt some down and replace them?
I would imagine since it uses standard 1/4" tubing you can find these connectors at the local hardware store. They may be a little different but as long as it threads into the cylinder and securely connects the tubing it will be fine.
Agree. I've bought them at Lowes and Home Depot. There are 2 types, though. The latest I bought was just the push-in type 1/4" tubing connector. Works just fine. The earlier type is plastic compression - turn to tighten. I've seen them as well in the big box stores.
