q-bumps
  • q-bumps
    Hey I have a question. I know it should go into the Scoring topic, but I thought I would start here.
    We are installing q-bumps in a few weeks and we are trying to get the place ready for them.
    One of the things that Quibica is saying is that we need a 5hp 60 gallon air compressor. We only have ten lanes and most of our linage is for league play.
    I am sure that we need the 5hp but can we get by with a smaller tank?
    Thanks for the help.
    Pat
    Re: q-bumps
    Pat....I would follow their recommendations.
    The bumpers go up and own with kids and adults bowling together.
    You will need plenty of air.
      Re: q-bumps
      Overkill.
      Pat, we run a 6.5 HP 60 galllon tank for a 32 lane center. PLENTY
      Use your own judgement, just make sure you can store a decent ammount of volume and you'll be fine.
      Do yourself a favor and run a valve for each pair for maintenance purposes.
      Mike
        Re: q-bumps
        do yourself a favor, get the 60 gallon. as jerry said the bumpers will go up and down as needed for each individual, so more air is needed. if you are able to interface the bumpers with your scoring. you didn't mention what system you have. but mike is also right. put a valve at each pair so that you can hook up an air hose to the main line so you can blow out your machines. if you can put the compressor outside or in a room other than your shop, i would do so. the noise from the compressor will drive you nuts and it always kicks on when you're on the phone.
        alex
        Cloth: ShamWow!
        Machine: Johnny 5
          Re: q-bumps
          Is an extra buffer tank(or more) not a cheap solution. I use an old tank from an old broken compressor as a buffer, works great!
          Gearloose
          So it goes.
            Re: q-bumps
            We have a 3.5 HP compressor with a 25 gallon
            tank running 10 lanes of the 1st generation
            Qubica bumpers, but our scoring does not interface with it.
