Ikon switching programs
  • Ikon switching programs
    I have an Ikon which while running a pattern for tournament has, as it left the foul line, will have the pattern number displayed and when it comes back to move to the next lane will revert to the pattern that is programmed in the daily planner IE, running program 2 and when it comes back show program 5 on the screen. No power loss and completely random. Anyone else have this happen? Contacted Kegel waiting for response.
    Television is called a medium because it is neither rare or well done.
    I had a customer machine doing this and it turned out to be the AM/PM changeover.
    His clock was out by about 40 minutes and when we added this discrepancy it matched up roughly with the 12 o'clock change
    Hi was running his lanes at an unusual time because of restricted Covid opening hours so it hadn't come up before.
    We set his clock off by a couple of hours and the problem seems to have disappeared.
    Technical Manager
    Bowltech UK Ltd
    www.facebook.com/ross.gibson
    Warning: The above post may contain sarcasm,
      Ross this is happening to me at 8:00 am while my pattern should not change over till 11:00 am as I have my clock set off by 1 hour.
