Kustodian ION pin deck
  • Kustodian ION pin deck
    Hello fine mechanics! We have a Kustodian ION with an LCD screen at our center and I've noticed that the area after the pattern (house pattern) up to the pin deck gets cleared of carry down, but the pin deck seems to still have quite a bit left after running the machines in the morning. During league I've its also been noticed that there are quite a few pin slides and still standing. What setting should I be looking at to determine if the machine is cleaning as it should be or is just just a part of the process that I need to be crawling down there an hand cleaning?
    I would check the output of cleaner first. (If I recall it should be about 30mi.)
    You can adjust the distance for the "Last Squirt" of cleaner to be a little closer to the pindeck.
    I have attached instruction for these 2 adjustments.
    I might also suggest checking the condition of the cushion roller also.
    If you continue to have problems, call Kegel at 1-800-280-2695
    You do not have permission to view this gallery.
    This gallery has 2 photos.
    let me be myself
      Working off of my not so great memory... From the startup screen press the Start Machine button, then System Settings, then right arrow button, then Last Squirt button. Use the plus or minus buttons to change the distance the left arrow button back to home. If prompted, save to all patterns.
      This gallery has 5 photos.
      let me be myself
