PHOENIX HEL P!!!!
  • PHOENIX HEL P!!!!
    Ok Guys... a new one on me. Very suddenly my machine (phoenix 8 pad) gives the error "lino did not wind". Yet when I go through the IO the motors and switches seem to test good. Also when I go to the lino menu and hit the down arrow it unwinds as it should and when I hit the up arrow it winds like it should.
    Any thoughts?
    Re: PHOENIX HEL P!!!!
    First i would check and make sure it's not binding anywhere.
    did anyone reset the number of lanes on the roll thats in there?
    Make sure the ends are tight on the wind and unwind motor shafts.
    Steve H
      Perhaps a dodgy micro switch to blame?
      It seems strange if the motor IS working in test then it may be electrical issue. I thought it was up to unwind, and down to wind up? Probably just my machine mind you! Ha.
        Thanks Steve... I have checked and actually we were about half way through the roll. I cut the roll and reloaded it. Things are smooth and tight.
          Alastair... I am guessing something weird electical. Possibly a switch but when I operate them with my finger they feel "normal" and make a positve click with good spring action.
          It is the suddenness of it that has me a little baffled.
            Sometimes when I get that error message all I do is increase the unwind time by one, this helps somewhat.
            Does it happen every lane? I take it the machine stops in the pindeck after reversing?
            It may just be that the motor may be on the way out.
              When you unwind the cloth through the test outputs make sure input010 is not on. If it is then make sure the cushion roller is dropping all the way. If that is ok just make sure that both of the switches aren't sticking and causing this problem. If all of this is ok double check the unwind time and make sure that it's correct for what you have lest on the roll.
              Hope this helps
                Alastair..... it happens on every lane. The machine makes it out of the pit about 15 feet and stops. Hitting the button on the handle allows the machine to finish the pass.
                I can hear the wind motors working on an oil only pass. But on the reverse of an oil only it stops three times. Really bizzare.
                JohnT thanks for the tip about 010. I am not 100% sure that it is off when I test.
                  Time to start changing things out. Put on a spare motor if you have one, if that fails then change out the switches. Does sound like the motor though?
                  Double check the reel, just incase it is split at the edge and it not winding up, may need a new uptake reel?
                  It can only be one of a few things, which is good news!
                    The reel could very well be the problem. If you suspect a bad cloth motor you can swap them they are the same. If I remember correctly there is a small plastic gear that will strip the teeth if the duster cloth is wound up to tight. On the first phoenix that we had I went thru 7 of these in less than 2 months before Phil from bowling supply installed some new softwase. When this happened I put the bad motor on the unwind side and the good one on the takeup side. I would have to unwind by hand until the roller touched the lane put a clamp on the duster roller to keep from unrolling further and then run lane. Had to do each lane like this.
                      Have you tried a new roll of duster cloth yet. Its been a few years since i've had a phoenix, but i do remember having duster issues. Like things coming loose or replacing the windup motor.
                      Steve H
                        Also make sure the cloth is on straight, if it's not it could give an error like what you are getting.
                          Is the PVC cloth take up pipe cracked? Causing the cloth to slip down.
                          - Albert Einstein
                            Check for, Bad fitting on the end of the carboard reel, cracked or broken take up reel, loose or spinning hubs on the wind/unwind motors, see if you can turn the unwid motor by hand, meaning grab the clean roll and see if you can unroll it.
                            Also disconnect input #5 from the PLC (#5 is for your duster down switches). Try swapping the windup with the unwind motor (they're the same). John T is correct about watching the Input #10 LED (#10 is the duster up switches.
                            Cloth: ShamWow!
                            Machine: Johnny 5
                              Any thoughts?
                              Did not wind what? Up or Un? This makes a difference on what you should be looking for.
                              Dennis
                              Baddest Tool Chest In Town
                              Adios, motor boater!
                              check this jam...
                              the ball stuck the table up
