what is the best option ????
  • what is the best option ????
    I have a pheonix 8 pads lane machine .... what id like to know is if i want to put less oil on the lane what is the best option : increasing speed or decreasing tention on the pads to transfer roller ?????
    Jocelyn
    Re: what is the best option ????
    Less distance in the pattern value for the outside pads
      King im not sure about what you mean exactly ..... i have only a year and a fiew months of experience with lane machine so plz dont be to hard on me !!!! lol !!!
      this is my pads configuration : 5-3-5-7-7-5-3-5
      and my program is :
      oil patern distance : 40 '
      forward shift to 2 speed at : 4
      shift to high speed at : 40'
      rt-1-5 forward 36''
      rt-5-10 260''
      rt- 10-15 31 '
      rt-15-20 31 '
      return
      shift down to 2 speed : 40
      shift down to low speed : 1
      rt- 1-5 0000
      rt- 5-10 255 ''
      rt- 10-15 32 '
      rt- 15-20 32 '
      distance between hits : 06
      this program was in the machine since i have started working here ( maybe its all wrong )
      ok now when you are saying ; '' less distance in the patern value for the outside pads ..... do you mean 5-10 and 10-15 on both side ?
        Try this:
        rt-1-5 forward 36''
        rt-5-10 120''
        rt- 10-15 31 '
        rt-15-20 31 '
        return
        rt- 1-5 0000
        rt- 5-10 120 ''
        rt- 10-15 32 '
        rt- 15-20 32 '
          In a pheonix 8 pad the 7 board wicks are supposed to be on the outside should go 7-3-5-5-5-5-3-7. This is because the 3 pad is expected to bleed out 2 boards toward the outside.Other than that you should deffinately cut back your 5-10 wick to half that distance and always remember you want to put the majority of your oil on the return pass and less on the forward pass. This will help to keep from getting carry down. I would also flip flop your slow speeds put the 4 feet of slow speed on the return pass rather than the forward pass.
          Do it right and you wont do it twice!!!
          Help-broken Part
          Greeting all.
          Thanks for looking.
          Bolton454
          Pin Damage
          Making TDM's adjustable.
          Gold Crown Masking Unit
