need help with amf express lane machine
  • need help with amf express lane machine
    I have had alot of problems with my amf express lane machine and I had it running but now for some reason the front solenoids that controll the vac wont release when the machine is turned on. Please help
    Typically it would be a sticky relay on the relay board.
    The obvious is make sure you have it in strip mode other than that relay.
    You could try taking the board out and locate the relay and tap with back of screwdriver to free up.
      If someone could help me my express machine keeps on spraying water as soon as I turn it on what could it be
        If the pump is staying on you probably have a stuck relay. Sometimes you can tap on the relay to get the contacts to break free but ultimately you will need a new relay if this turns out to be the issue. Is there another relay of the same type on the relay board so you can swap the two relays and see if the problem goes away?
