My waste tank has no lid !!!
  • My waste tank has no lid !!!
    K guys so I just got here and my waste tank has no lid. Looks like someone took out my filter and tried "cleaning" it and here it sits. So, with that being said, any suggestions as to what to seal it back up with ???
    Thanks Guys
    IT would help to know ware machine was cleand the lid may be thar ????
    a look inside machine wont hart
      K So I found the lid in the kitchen floor drain. (someones cleaning gutters with a tooth brush !!!) Now, what type or kind of a gasket (sealer) should I use ?
        Use a HIGH QUALITY silicone caulk!
        If its gonna go wrong, it'll go wrong here first
          Thanks, I just hope I will have enough time for it to set and be ready before league tonight !!
            Won,t take long to set, I use cord gasket.
              you can get fast curing silicone.
              normally I use blue RTV but permatex also has
              http://www.permatex.com/brand_right_stuff.htm
              cures in 1 minute.
                Thanks Guys. Went with the Blue rtv. I got about 8 hours till league. Hope it's enough time.
                  you'll be fine then, it only takes about an hour for it to be liquid tight. the full cure time of 24 is for pressurized applications like car engines/transmissions its a little overkill for holding some watery goo in a tank.
                  Streamlane Mask Halo Lights
                  Baddest Tool Chest In Town
                  Adios, motor boater!
                  Aluminum Repair and Welding
                  http://aluminumrepair.com/...
                  Hi, guys.
                  check this jam...
                  the ball stuck the table up
