Phoenix Pad Machine Wind/Unwind problem
  • 90xli
    A couple possibilities I see as I was running mine today. The keypad is worn out and is depressing multiple buttons. The wires to the relays are loose and causing a short when energized or you have a stuck relay. Try moving the relays around to see if the problem moves to another circuit.
  • 8270king
    Do you have your thumb on the start switch on the handle?
  • Hex_Nut
    started a topic Phoenix Pad Machine Wind/Unwind problem
    My Phoenix 8 pad machine has sprung a rather confusing problem. Here is what happens. Plug in the machine, and press menu to cycle through the prompts like you would to reset the paper counter, or enter the managers password. When you get to lino ctrl & reset, the paper unwind motor starts running. You hit menu again to Phoenix start menu, and the unwind motor turns off, and the wind-up motor turns on. To get the wind-up motor to turn off, you have to cycle all the way through the menu back to Phoenix start and then it turns off. What gives!?
Stahl's "Tuffy Super Jam Stopper" in action!
So I decided to try a few of these, I mean the idea totally makes sense and recently I saw these in action and liked what I saw.
Basically, it's meant as an extension...
Roller Clutch issue
Has anyone had to remove the plastic ring in the back side of the plate in order to achieve good indexing? I now have 2 roller clutches without the backing rings in service. Either...
Pictures of new machines being installed...
Here are the accelerators and pits that came with the lanes, kickbacks, gutters, power lifts.
This a new way of building the supports for the lanes...
Baddest Tool Chest In Town
Adios, motor boater!
check this jam...
the ball stuck the table up
