pheonix s error: Message_No Message
  • pheonix s error: Message_No Message
    HELP!!!
    PHEONIX S having MESSAGE_NO MESSAGE appeared on the keypad.
    Believed the PLC lost the programme cos i've hooked up the PHEONIX S PLC to the ECHO and the MESSAGE_NO MESSAGE still appeared.. while the ECHO PLC in the PHEONIX S its worked very well..
    I need help or advice for this matter...
    You need to change your battery in the computer
    Then you need to re-load the correct programming for your machine
    Call Kegel so they can help
    800-280-2695
      thanks king,
      I will try.. will let u know..
        I've had the same problem in the past. Don't panic! The good folks at kegel will walk you through the key commands to get you up and running again.
          hi king & 90,
          already changed the batt.. still NO MESSAGE.
          in comm with KEGEL.. password was given with the NO MESSAGE unlock instruction. keyed the password the ???? appeared again with an irritating beep beep beep.. matbe its telling me wrong password.. the BEEP sounded again when pressed WRITE or DOWN button..
          i like the step 7: If that doesn't work don't give up! It can be fixed! Call for help!
          BEEP BEEP BEEP
          Streamlane Mask Halo Lights
          Baddest Tool Chest In Town
          Adios, motor boater!
          Aluminum Repair and Welding
          http://aluminumrepair.com/...
          Hi, guys.
          check this jam...
          the ball stuck the table up
