kegel kustodian
  • kegel kustodian
    hello ,Ihave kegel kustodian have ine problem when start from foul line start very well and go run but when is on pindeck back more lees from pin 5 and all water stay in pindeck ,.
    1.- how check it travel to end the lane 7-10
    posible the swich or motor roller duster not work.
    thanks for your helpme
    jesus
    Do you use kosi? the pattern distance setting could be differnt.
      You may need to adjust the travel distance in the cleaning menu.
        What kustodian do you have ?
        As stated above you might want to go in cleaning menue and check your forward distance subtract number
        Mike
          On forward distance, each number you subtract will bring you closer to the tailplank. you have to do the same for reverse distance.
          Baddest Tool Chest In Town
          Adios, motor boater!
          check this jam...
          the ball stuck the table up
