Lane Machine Cord
  • Lane Machine Cord
    hey guys im looking for a good cord for my kustodian the cord that i have now is kinking up and its only been on there for like 4 months we bought a roll of it from lowes where do you get your cord for you machine
    I ordered mine online. Just make sure that you get the same type of cord as the original because it has a tougher jacket. It is not real simple to find, but at half the cost of the original well worth the search. I got mine about 2 yrs ago and don't remember where from.
      Go to lane maintenace 2nd page cuirly Q power cord , alot of info.
        ok i will look and see what i can find
          ok will do thanks for the help
            I get mine from here:
            http://www.fourstarwire.com/industri...ble-cords.html
            12/3 SJTO Cord #F1756 It's abought $1.20per foot.
              how does this wire hold up in comparison to the one that comes with the lane machine?
                You can pay twice as much if you want or you could get it here. https://www.wireandcableyourway.com/SJTO-300V/
                If I were going to replace the cord which I think is 120' I would use SOOW/SJOOW 80cents per foot at the above store. The thermoplastic PVC coating on SJTO is probably where your twists are happening so getting the same type of wire that's on there now will likely result in the same thing.
                  https://www.wireandcableyourway.com/...0v-ul-csa.html
                  Idiocracy
                    I easily prefer the stiffer and wavy stock wire because it doesn't tangle up as easy as regular straight (and often softer, more bendy) cords. Got a stock with a used parts machine we got recently, and use that with the Twist-N-Lock rather than stock Euro socket that we had earlier.
                      You might be the only person I've ever heard of who loves the stock cord, but hey its your choice . Do you happen to have a picture of the Euro socket that wasn't a twist-lock?
