Kegel Kustodian Plus
  • Kegel Kustodian Plus
    Having trouble with the stripping. Kustodian is stripping the left side of lane and not the right. Cushion roller is wet on the left and dry on the right.
    Cushion roller - new
    Mike
    Mike, please check links where the cushion roller ends pass through. possibly dragging on inside frame and binding. I filed down oil lite flange and some of plastic end that portruded through to eliminate chance of hangin up before. Also, there should be a washer at other end on of link on the inside where bolt goes through. Check these and do test out #12 duster unwind motor function on approach or in shop to watch how cushion roller drops. When I did have small problem before like this, I did get an error? Let us now what you see after checking it over.
      Wonder if your head timing is way off
        1. Do a volume test...
        2. Open the lid...do a test clean...and watch it run.....
          I've had that problem when someone forgets to put the cleaner head back in the block after chaning the duster cloth.
            Thanks for the replies...ended up being the unwind time had gotten reset half-way through the roll of duster cloth
