Squeegy blades
  • Squeegy blades
    I thought I seen somewhere on here where to buy cheaper squeegy blades other than from Kegal. Where can I order them and do they work just as good?
    Thanks,Sid
    http://www.bowltech.com/forums/showt...764#post411764
    Heres a link were I discussed getting them.
    I found a local place to buy the blades $50 each
    The part # is E00601BLU or 56105542 not sure which one, but probably one of these is the actual APA Nilfisk Advance part #.
    You might be able to find these locally at Janitorial supply places. The type of place that sells supplies for floor cleaning machines. They may not have them in stock but they will probably be able to order them in for you. You can even try to contact Nilfisk Advance to find out where there is a nearby vendor to you
    http://www.advance-us.com/findadealer.aspx
    Maybe try to contact the company to find a dealer near you
    Nick
