Walker settings
  • Walker settings
    I was having some pin sliding issues when I first put the machine in service
    I turned off the "wipe" feature and I set the duster lift to 0
    No more smear on the rear of the pin deck
    No spraying decks today......on the second daytime shift we have only had one off spot
    Sooooooooooooooooooooooo what you're saying is, all of the time, effort, and money is wasted on sprays, stickers, and coatings on pindecks if the lane machine is cleaning the decks properly? WOW! Who would've ever thought that!?
    Cloth: ShamWow!
    Machine: Johnny 5
