When moving machine from one lane to another it will sometimes leave a streak about 4'' x 12" on the approach. This is coming from the duster cloth on the left (7) side of the machine. It doesn't do it all the time. I recently changed the cushion roller, not sure if I might have done something wrong when changing it. Just took the old one out and put the new one in.
Kegel Kustodian Duster Cloth
With cushion up at home against switches, Is there alot of play on that side ? like being able to lift it up and down ?
Maybe you just have to re roll your kloth, or check you unwind time...
MikeDO A NEAT CLEAN JOB, AND FIX IT RIGHT THE FIRST TIME. THE ONLY WAY TO WORK.
This will also happen if you are pressing the button on the hadle to unwind cloth for the next lane before getting over the "hump" on the approach inbetween lanes.You don't have to be crazy to do this job...But it helps!
