I forgot to call Kegel, so I thought I'd post on here. Does anyone know when the transfer brush should be changed in the lane machine? I haven't seen or heard anything about it, so I was just wondering. Thanks in advance.
Transfer brush--how long does it last?
Our crossfire is five years old and we changed ours late last year as it just didn't seem to retain the oil in the brush well, it began really throwing the oil around in the direct areas around it and occasionally dripping on the lane and approach when it was in the raised position. Once changed all the issues dissapeared.
I did read somewhere in the manual I think that Kegel reccomend a change every couple of years but it would obviously depend on usage.
I wouldn't replace it until the ends become frayed and no longer hold the oil properly. It also depends on what surface you have.Conditioner: Pantene Pro-V Brunette Expressions with Color Enhancer
Cloth: ShamWow!
Machine: Johnny 5
