BUFFER RPM'S
  • BUFFER RPM'S
    I have a sanction standard. The buffer rpm's are 720. When I was talking to Kegel, the tech said, on the battery machines they are running 500 rpm's or so. He told me that it made no significant difference in how the pattern graphed. Does anyone have any observations on the subject?
    we went from an ac machine to a battery machine with no difference in our scoring (we run graphs every week for every league). we never changed our pattern until we were able to change pump output per load with the m31 upgrade. all that did was make things better, so the benefits outway the difference imo.
      I like the Walker and it's 500 rpm buffer speed...if anything I think there is less oil sling off the brush which is a plus - no pun intended
