hey guys i have a kegel kustodian that is over spaying into the gutters and i have adjustedand i have replaced the the body the and the the retainer cap and the spray tip nothing i do will help
please help
Question ... if the machine is over spraying, could it tend you to believe that the squeage is not working properly. I ran a clean only yesterday, when finished their is still a slight very slight film of cleaner on lane. I pulled an old lint duster down lane ... then very dry. Then ran the oil only. Main thing I see different is in the buff only area, the buff area is very nice film of oil, where before you could see lines in the oil .....wash board type lines. Tried numerous things, still the same result on cleaner.Every day is a good day, some are just better than others.
The middle jets should be on a 45 degree angle to the lane surface.
All the bodes can be moved and the tips angled as necessary.
the middle jets should be the 11003 or 8003...and the outside jets should be 1501...on the front of the jets.
Also typing in all capital letters is like screaming.
do you have the right tips in? they have numbers on them. the 1501 go on the outsides. What board are the outside jets spraying on? Cover 3 of the jets at a time and prime the pump. you'll see the spray pattern for each individual jet.
Leman. the reason you didn't see the washboard on an "oil only" is because the oil doesn't have time to collect on the end of the transfer brush bristles as the machine travels through the backend and back.Conditioner: Pantene Pro-V Brunette Expressions with Color Enhancer
Cloth: ShamWow!
Machine: Johnny 5
