What if any would be the difference In your oil pattern if you switched from Infinity oil to Offence oil.
WHAT WOULD IT BE..
I believe the predictability of Offense is better than Infinity. The midlanes opens up with Offense and don't get so wet/dry, especially if you have a low friction surface. Which makes moves easier to read for the bowler and tends to yield higher scores. Offense is also less temperature sensitive on the lane.
Jerry is correct, the ball will read a bit earlier. Although Infinity is more durable, the carydown will weaken the back more and can make for more difficult moves.Conditioner: Pantene Pro-V Brunette Expressions with Color Enhancer
Cloth: ShamWow!
Machine: Johnny 5
