I was doing a oil volume test last night and when the test ended the block stopped for a couple of seconds and
then started to run again and then I pushed the menu key to go back to the oil pump volume menu and
the cushion roller lowered.Any ideas on this ?
Cloth: ShamWow!
Machine: Johnny 5
