Does any body know if the drive motors for kustodiann machines are inter changeable? We have a kustodian b a friend has a spare drive motor but isn't sure if they bought it when they had a kustodian or the i=on that they have now
Drive motors
The Ion drive motor does not have the same drive motor has the Kustodian model you have. You can check the label to see if it says 24v dc or 90v dc. If it's the 90v dc motor then you're in luck and can use it in your machine.
[FONT='Trebuchet MS', Verdana, sans-serif]The Ion drive motor does not have the same drive motor has the Kustodian model you have. You can check the label to see if it says 24v dc or 90v dc. If it's the 90v dc motor then you're in luck and can use it in your machine.[/FONT]
