i have a old elite that runs off the pindeck everytime?
lane machine runs off pindeck
Does it do it for every pattern in the machine?Factory & Converted A-2 (US, Ger, Jap)
Check the end to pindeck setting for each pattern. look to see if the LDS sensor is overriden. The distance is usually farther down the lane if it runs off the Tach only. You would most likely be getting travel errors if a sensor were bad and not overridden.Conditioner: Pantene Pro-V Brunette Expressions with Color Enhancer
Cloth: ShamWow!
Machine: Johnny 5
Originally posted by Kanga View PostWhat I was thinking.Conditioner: Pantene Pro-V Brunette Expressions with Color Enhancer
Cloth: ShamWow!
Machine: Johnny 5
"No she di'int" *SNAPS*
LolFactory & Converted A-2 (US, Ger, Jap)
