Have instructions for changing buffer brush but not a clue as to how to adjust transfer brush to buffer brush crush. Please help.
Transfer Brush To Buffer Brush Crush
Do you have a one piece transfer brush system or a two piece? (Does your machine have the buffer separate from the transfer brush or are the buffer and the transfer brush all one assembly?)(Psalm 37:29) The righteous themselves will possess the earth, And they will reside forever upon it.
It should come adjusted from the factory. Some are off but close enough to not be a big issue.Conditioner: Pantene Pro-V Brunette Expressions with Color Enhancer
Cloth: ShamWow!
Machine: Johnny 5
