Phoenix S Model C "Duster cloth empty"
I keep getting a message every few lanes stating duster cloth is empty. The micro switch is pushed in. Could the switch be bad?Support your local mom and pop shops!!!!
www.dommsbowling.comTags: None
Originally posted by JohnMart View PostI keep getting a message every few lanes stating duster cloth is empty. The micro switch is pushed in. Could the switch be bad?
Did it just start out Of the blue or was something replaced recently?Conditioner: Pantene Pro-V Brunette Expressions with Color Enhancer
Cloth: ShamWow!
Machine: Johnny 5
That sounds about right. I did have the cushion replaced not too long ago. What should I do to fix this?Support your local mom and pop shops!!!!
Did you put the original style roller on or put the cover with the wrap on?With the machine laying down on the approach and the cloth loose, manually raise and lower the cushion roller by hand. It should mOve completely free. Raise and lower one side at a time. Also you should have about 1/16" free play side to side. Add or remove the nylon shims to achieve that. Check the duster arm where it mounts to the frame. This spot is often over tightened and deformed, which can causevthecarm to bind against the frame.Conditioner: Pantene Pro-V Brunette Expressions with Color Enhancer
Cloth: ShamWow!
Machine: Johnny 5
Originally posted by JohnMart View PostThat sounds about right. I did have the cushion replaced not too long ago. What should I do to fix this?
Are your dustermotor brakes working fine, sometimes when machines get older the gork on the motorbrakes get greasy and slippery which cause them to turn a little, just enough to (de)activate the switches. what is your default unwind time??
