my pump was running at only 8 psi so i put a longer hose on and got it up to 20 psi. now I'm getting incesistant volume tests and the stream seems weak, any help would be great. thanks, Sid
weak oil stream on Kustodian
check the valve. You will need to disassemble it, make sure to not lose any of the washers! sometimes just a couple of strands of hair will make there way into the valave and cause a reduction in oil volume.ME&My68
8 PSI is too low. You should be between 10-20 PSI. I set all machines at 15.
As for you issue, I would check the internal tank filter and in-line filter if you have one. If you have the in-line filter, it is suggested you eliminate it.Conditioner: Pantene Pro-V Brunette Expressions with Color Enhancer
Cloth: ShamWow!
Machine: Johnny 5
Originally posted by dustin View PostI have a pheonix S(red) lane machine. Should I eliminate mine also. What is the purpose of doing this?Conditioner: Pantene Pro-V Brunette Expressions with Color Enhancer
Cloth: ShamWow!
Machine: Johnny 5
Originally posted by me_and_my_68 View Postcheck the valve. You will need to disassemble it, make sure to not lose any of the washers! sometimes just a couple of strands of hair will make there way into the valave and cause a reduction in oil volume.
Even though the tip is clear of tape, it is possible for some of the tape to become stuck in the threads after the fitting has been removed which gets pushed into the valve body upon inserting the fitting into the valve. If the threads are not chased, the fitting can push any tape left into the threads of the valve body.
