Kustodia Plus oil control valve
  • Kustodia Plus oil control valve
    Have a valve that intermittently quits working. I've taken it apart, clean, reassembled, which has always got it working again but not so lucky now. Are these valves known to fail? It's only a year old, as the original one had pressure issues even after cleaning it.
    Is there a grainger number for this valve? Kegel number is 154-1209
    Thanks
    Mike
    I just replaced mine last week. So yes they do fail, I had an oil leak/drip problem so I can't say for sure if the oil that got on the wires was the cause. here is a little pdf from kegel about it.
    http://www.kegel.net/downloads/154-1...aintenance.pdf
    the biggest thing I was told is that the valve screwing into the union should be finger tight, I'm sure you realize by now that a healthy coating of Teflon tape on the connectors going into the union/valve is needed to stop it from leaking.
      http://www.bowltech.com/forums/showt...m-on-Kustodian
      Here's more info that might help solve your problem.
