Phoenix-S Model B Buffer Brush Motor Contactor.
  • Phoenix-S Model B Buffer Brush Motor Contactor.
    Does anyone know what the part Number is for the 153-1004 BUFFER MOTOR CONTACTOR - (115V).
    my Phoneix-S Model B buffer motor contactor is acting up. It is occasionally not making contact.
    The contactor stopped working this morning, I have a city tournament, and I have to sit one the lane and when the contactor doesn't make contact I have to redo the lane.
    The markings on it, have worn off so that I can not read the make or model number out.
    Any info would help.
    I need to get this Monday morning and get this machine running properly. If I can get the proper number hopefully grainger will have instock, or get it next day.
    5B122 from grainger works in my 8 pad phoenix
    Go Pirates
      IEC Contactor, 120VAC, 12A,Open, 3P Grainger# 3DY28 $131.54
      I'd shop around for a $30.00 one.
        There should be a third set of contacts in the contactor that would allow you to move the wire over and use a different contact till you get a new one
        Television is called a medium because it is neither rare or well done.
          153-1004 is the part number...
            JBing, your correct and mine tested good!
            Found one for $41.99 on Amazon (Contactor)
            http://www.amazon.com/Telemecanique-.../dp/B003UR0OBU
