phoenix drive motor.... need help
  • phoenix drive motor.... need help
    My phoenix C 8 pad drive motor failed. I opened the gearcase and found that 1 of the gears were spinning on it's shaft. I can make this work (for a while). Anyone know if repair parts are available? A new one gearcase?
    TX
    Go Pirates
    I've welded the gear to the shaft with no issues.
    Cloth: ShamWow!
    Machine: Johnny 5
      thanks for the reply. Due to our insurance regs I can not weld in my building. I think I will try brazing it on with MAPP torch. What a crappy engineering design. Stamp ridges into the shaft then press the gear on
      Go Pirates
        I have a used one call me any time
          Wepauls,
          If you're gonna sell something, I believe you need to send a PM. This is twice I've seen you try to sell stuff in forum post.
          Cloth: ShamWow!
          Machine: Johnny 5
            pm has ben sent
            IT BETTER TO SEE IF WAT I HAVE IS WAT IS NEEDED
            I have posted in things for sale with no response's
            THAR ARE TIMES I JUST GIVE THINGS AWAY
            [ for cost of shiping ]
            [ BETTER THAN STRAPPING THINGS SOMEONE ELSE MAY USE ]
