Squeegee chatter.
  • Squeegee chatter.
    Kustodian walker. Noticed recently that the squeegee is chattering quite a bit, is this common? It's not leaving any liquid behind but looked like it didn't quite clean as well in the back end. Just a few small smears from some carrydown, very faint and scores are still good. When the PBA regional was here with their A22 it did that and he said it just meant the back end was very clean. Our does it in the heads tho too and it's not constant btw. On the first lane i have been spraying a bit of cleaner in the heads and on the lino duster roller since you cant spray the lane once like i used to do with my Phoenix. This is season 2 with it and they are the original blades.
    Charley
    There is a lack of cleaner - guaranteed
    Do a cleaner volume test
    You will probably need to replace your neoprene tube in the peristaltic pump and do a volume and calibration test and re adjust the pump
      Jerry is right but I'll add, it's not the squeegee blades, it's the cushion roller. You should either flip or replace your blades too.
      Cloth: ShamWow!
      Machine: Johnny 5
