A while back I found that I was consistently getting around 15+ lanes worth of cloth left on the roll when the counter reached zero. I thought perhaps the size of the cloth had been increased and/or I was far more efficient at fitting it. (We use Kegel EZcore). I increased the lane count accordingly.
The machine has an intermittent fault of not unwinding the cloth on the first lane of a session, ie brings up the message "duster out" after pressing the red start button. Menu out and re-start usually clears the problem. It only ever does this on the first lane of any session and only once in maybe four sessions. I have investigated this problem and the relevant led on the control module lights every time and the wiring seems AOK so I suspect a motor fault.
Can anyone see a connection between these problems?
Could the failure to unwind be anything other than a failing motor?
If I increase the default first unwind time at the next cloth change do I need to make any other adjustments?
If you've read this far thank you and thanks in advance for any advice
