Lanewalker Blew Fuse
  • Lanewalker Blew Fuse
    Have a Lanewalker which blew the fuse. No drive motor run after replacing fuse. No manual so shooting in dark. Have spare motor and speed control section. Need help to correct problem.
    Kustodian Walker or earlier model?
      Check all the rest of the fuses? What colors are the lights blinking on the speed control board? (the color and speed of the blinking will tell you certain things.
      Marty - pro Bowl West
      56 Jap A-2's Qubica VDB's
      2 Kustodian Walkers
        When is the last time you took brushes out of motor and cleaned it? Did the fuse blow again? After changing fuse and still no motor, did you check for voltage at the plug to the motor?
          This is the old fashion Lanewalker that hops.
            The motor is probably filthy. if you feel comfortable taking it apart to clean it out, go for it. Or take it in to an electric motor shop to have it cleaned out and checked out.
