Phoenix
  • Phoenix
    Having a problem with the DBA Phoenix, since a new cleaner spray pump was installed, it will not spray though the front jets whilst the valves are in. When i remove the valves, it sprays perfectly but leaks real bad when phoenix is pulled off the lane or is just sat still. obviously i need the valves in but how can i when it doesn't spray with them? Machine is running on 4 jets at the front and original piping. Any ideas on how to solve this??
    http://www.kegel.net/default/default.asp
      Check the 3/16 pressure relief tube that goes back to the tank
