kegel volume tests
kegel volume tests
what is the output supposed to be for oil and cleaner volume tests....new kegel custodian lane walker ....i cant remember i think its like 26 for oil and like 30 for cleaner ....any help is always greatTags: None
Oil - 16ml or 20 using the calibration program - depending on your pattern is a 40 or 50 mic stream
Cleaner - 30ml for 4 passes of the cleaner head
Your machine should have had a manual - I would suggest you read up on your machine - that way you do the volume tests correctly
On the touch screen for the volume tests...there are instructions. You should be able to get the idea once you are there. If not...give me a call and I will walk you through it. And if you need to...Kegel is always available to give you a hand. 800-280-2695TSM & TSM Training Development
