Squeege pitch adjustment for Kustodian +
  • Squeege pitch adjustment for Kustodian +
    What should the pitch adjustment be for squeege blades on Kustodian + lane machines? Should the front blade be slighty higher when in down position or even between both? Is this adjustment set on the adjusting threaded bolt coming from the cam to the squeege assembly?
    chip
    I believe the book calls for even. Yes the adjustment is obtained by the rod from cam. As long as rear blade is making good contact, it should do a great job of stripping. remember to always test clean!
      Jacko is correct,
      the two blades should touch your straight edge when you check adjustment... Also be careful if you make a 1/8 to 3/16 blade crush adjustment the pitch can also change some with that..
      Mike
