HVO won't move
  • HVO won't move
    Push start button and everything engages. No drive motor. Gives encoder error. Press 0. To return to foul line. Nothing.
    Speed control box? His can I tell? I do hear the relay click when I try to return to foul line
    Have you done a test and tested for voltage to the motor?
    There is a fuse in the speed control box i have seen blow..
    Mike
      Was a fuse inside speed control box
      Thanks!
        Glad you got it sorted,
        another way to check is lay the summit on the approach, enter the test function and press the forward or reverse arrows. You can set a power% if you wish. Pressing the up button will set the motor to travel forward, and down button reverses the motor.
          Mike
          what about drive into the pit mikey? cannibalism at its best!
