OIL ON HEAD TIMMING BELT
  • OIL ON HEAD TIMMING BELT
    Has anybody seen lane oil on head timming belt before?Have a kustodian with brush upgrade,I can wipe oil off belt every 3 or 4 lanes.It shows up in a couple blotchs on the 7 pin side of oil head.
    I've only seen it when my chaser knocked the fuze out of the transfer roller motor and the oil piled up and plattered all over. Is the wand/hose leaking above the block it's locked into? Is the brush clogged and the oil is piling up?
      Can you post a pic?
      Cloth: ShamWow!
      Machine: Johnny 5
        Oil on head timing belt
        Had the same problem a while back turned out to be hose to oil head rubbing into buffer brush on the 7 pin side. Had to walk along side of machine to catch it doing this. Repositioned hose by turning oil nozzle in holder. Stopped drips.
