K+ cleaner amount
  • K+ cleaner amount
    I was wondering if anyone knew what the amount of cleaner should be when you test volume output for the kustodian + machine with the valve closed all the way? I was doing maintenance on machine and it seems it not using as much cleaner as before.
    12ml for the DC cleaner
      For the newest machines the book calls for 25ml. to 30ml. for 4 passes of the cleaner head. On the older machines I believe it was 25ml. for 3 passes. Kegel recommends replacing the tubing in the cleaner pump annually, or when cleaner volume output is negatively affected.
        1st gen K+ calls for 12ml-14ml
        Newest is 25/30ml
        Consult your manual
          Depends on whether it has the AC or DC cleaner pump.
          Cloth: ShamWow!
          Machine: Johnny 5
