Kegel phoenix C with plenty of problems
  • Kegel phoenix C with plenty of problems
    Start off the night by preparing to dress lanes for league. Got 2 done then here come the problems!
    H7 - Oil head travel error (done this before, no biggy just reset)
    SA - squeegee down error ( ok bit annoying now)
    S9 - squeegee up error ( getting ridiculous now)
    D5 - duster unwind error ( pulling my hair out now)
    D6 - duster wind up error ( practically bald now!)
    All these take turns in popping up, so only managed to get 2 lanes dressed; great -.-
    Had the same problem a couple of nights back, changed the squeegee mech as a pin was bent. All worked ok last night but tonight its hell again!!!!!
    Any help given would make me love you all!
    Make sure your terminal strips are all secure and snapped down tight
    Television is called a medium because it is neither rare or well done.
      I would take the terminal strips off - and see if there is oil under them causing these issues
        Looks like you may have lost the outputs from the tower relays that control the oil head, brush lift, squeegee, Duster motors and oil pump. I would check the common link wire in the A1 terminal on the back of the tower relays, this may be loose or out of the terminal.
        Technical Manager
        Bowltech UK Ltd
        www.facebook.com/ross.gibson
        Warning: The above post may contain sarcasm,
          The only time I have seen all those errors pop up like that is when the plc output fuse is blown.
            It is amazing what can go wrong when either a clip or wire is loose/unattached cheers people
              Was it on the fuse holder?
